Drone Camera
Queensland
My yuneec Q500 4k camera is taking photos and video but camera will no go up and down and side to side can someone help or do i need new camera.
What do you mean with side to side? Is the camera levelling? Did the drone have had a crash? Did you try the black wire to connect camera to the drone instead of the slide contacts?
If camera tilt is not working it is in most cases the wiring or transistor that sends PWM signal to gimbal. Camera is not affected.
Reactions: DoomMeister
Depending on source of the problem if the transistor is defect this may be a solution:
But check wiring first...
Sorry tilt is not working. No crash that im aware of. Black wire is connected no slide contact.
The second level link in the post above has been changed. The new link is either of the following:
or See attachment 63 of the PDF document attached to Way To Fix Drones project
I am just amazed at the knowledge and sense of sharing on these forums. KUDOS !!
Telefoni
