Of course not, That's why there needs to be some MOD that goes on the prop arms above the canopy somehow. Obviously the landing legs will have to be in a "down " position before touchdown to protect the camera. The idea is to protect it from a rapid descent & getting blown to smithereens on impact...? ? ? Surely some 3D thing maker whiz bang engineer in the forum could come up with a "viable" design that could be retrofitted to suitably work with the Typhoon?I could see this possibly working on the Q500 series with fixed legs like the Phantom, but not on the Yuneec Hex series with 360 cameras and retractable landing gear.
My q500 fell from about ten ft and crashed onto grass and smashed to pieces yuneec drones are not built very well with plastic airframe? However! I've upgraded to the carbon fiber rakonheli kit which I will recommend . Although lighter and stronger, I believe you could fit this? But I suspect a fall from less than 50ft or more? The parachute will be useless?Xpfreak,
By the time it is deployed your drone will already be on the ground in pieces. That is if you fly at the maximum legal ht, the time for the auto switches to work the drone has come to grief. Plus the huge amount of extra weight, what is the trigger time and angle that it deploys and size of the canopy etc, etc. They don't give you much confidence after you do all the calculations and if you fly safely and legally the need of a parachute is one in a million. Sorry if this is a little dismal but have looked at a lot of systems for waivers here in Australia and they don't add up to safety or costs with price or extra weight etc. Johnno Hennessy.
My input,,,,,,,,,,
The extra weight and wind resistance during flight is a negative that's been mentioned already,
Secondly, have you ever seen a drone fall from the sky?
It tumbles all the way down, the lines for the chute might tangle in the the airframe,,,,,,
I got better things to loose money on,,,,,,,
Oh yeah, what if the sensor malfunctions and deploys the chute while you're just getting that prime video shot?
I wouldn't expect the need when flying at maximum height? As theirs nothing to run into at that height? Unless theirs other drones in the area?Yea sure their is pros and cons but is it not best to have 1 if your flying at the maximum hight and if it's a reliable system then should not have any false triggers the picture I posted with the brackets if someone could make the same only larger to clip round the body of the H then it's not using the arms or the legs
Here's a less expensive version same thing
Automatic Escape System Parachute for DJI Quadcopter Phantom 4 Or 3 Drone Parachute Accessories
5.0
1 Review3 orders
US $74.25
US $90.55
-18%
Color: black
Quantity:
Additional 2% off (10 pieces or more)
417 pieces available
Shipping: US $6.61
to United States via China Post Registered Air Mail
Estimated Delivery on 06/26
That would be quite AWESOme if someone could design a holder of this rig for the Typhoon H! Any tinkerers out there with 3d printing stations?
I have crashed two of my q500 drones. Both crashes only resulted in minor damage and they both fell more than 100 feet. I hit power lines.My q500 fell from about ten ft and crashed onto grass and smashed to pieces
We can debate the Pros and Cons of parachute systems aii we want, but in the iong run, it may be something we'll all have to do, if the FAA ever gets its rules for flights over people finalized.
Is there a video of one actually working?
