Factory gimbal calibration
I knocked the camera off my H for the second time and broke the gimbal mounting plate again.
After repair everything works fine I can manually pan-and-tilt and all the modes work however the camera is aiming at the right skid on boot up even when the pan knob is in the center.
I did several gimbal and accelerometer calibrations with no success. I read all the other threads regarding this issue and there does not seem to be a definitive answer.
The last time this happened I called Yuneec and they said that the gimbal needed a factory calibration so I sent it in. When I got it back everything worked great.
So I don't want to wait a month to have the gimbal calibrated by the factory does anyone know the procedure to do a factory gimbal calibration? Or is this something that requires special tools and software?
I would call Vertigo Drones or Terrestrial Imaging and see if they can do it. I do believe it requires special software.
Is it facing 90° to one side? If so you might have screwed the gimbal at that angle, it happened to me once I repaired the lower mounting plate; I removed the 4 screws and lost the front of the yaw motor. Easy fix just remove and realign
Greetings
Call Mike or Chris at Terrestrial. I don’t believe Vertigo has the ability to perform the factory camera cal but I know Terrestrial does. Although in New Jersey they have a quick turn around. Tell ‘em the 920 guy sent you;)
Yuneecfan49
