Firmware and OEM Manuals
Reactions: aurelio_kta
Thank you!!! I just discovered that my university network was blocking the links for some reason!! Thank you!!!
That would be typical since they contained .exe files. Easy IT management, block everything external.
I purchased a H+ from the UK and live in the US. I tried to check for updates and none are showing when checking. Must I stay with the UK updates? or can I use the US updates?
You can update with the US files. Get the pdf document in this thread Way To Fix Drones project and refer to the attachment for changing firmware on the H+.
I did that, everything else updated, except the camera. I have tried many times to update the camera using the included SD Card.
Yes, I know where you are at on this it is being addressed here SD Card for H Plus C23 Camera. This is so people will know how this is being dealt with. The camera was updated at last post this AM.
go88taixiucom
