After rebooting the Q and the ST10 did you do the binding process?I did an update on my q500 4k today and now no power to the blades. it has lights and sound just no spinning. any help and I'm new to yuneec. also I just did the update to the drone.
There are Youtube videos that can help do the binding. You have to do the aircraft and the controller at the same time to complete the binding.yes but I think my problem is I only did the drone. Im working now on the st10plus
Ah, okay. Let me know how it goes.what I meant to say was that I didn't update the transmitter just the drone. I'm working now on that. I followed the directions on binding but it would not bind.
Ok I updated the transmitter and still not binding. I go through the process and see the model number on the screen, tap it and hit ok but it goes away after that. The camera is recognized and stays on the screen. I can adjust the camera up and down but no activation of the blades. It gives off a descending tone after holding down red button.Ah, okay. Let me know how it goes.
Create a new model, give it a name and then bind. Be sure to bind the Q500 first and then the camera. You may have to enter the password for the camera.Ok I updated the transmitter and still not binding. I go through the process and see the model number on the screen, tap it and hit ok but it goes away after that. The camera is recognized and stays on the screen. I can adjust the camera up and down but no activation of the blades. It gives off a descending tone after holding down red button.
Nice!!!Steve, I can't thank you enough! I created another drone and it bound and looks to be fine. I will fly it in a while but I've got a good to go on the transmitter and the lights. Hope for the best! Thanks again
Should be 1.07what is the version as of today on a 500q 4k i just got from a friend on a deal and i just doing my home work
and what is the numbers on a full load battery ?
The 1.4 would be for the Q500. The current version is 1.07 for the Q and st10+v01b29c for the ST10+.Hi... I just checked my ST10 Hardware version and it is 1.4. Would I realize much benefit by updating it ? It has been working good.
You should do the updates. There is a pdf file included in the download that explains the update procedure. Also some Youtube videos. The listed improvements on the download page are:
• Return to Home Improved: In case of loss of signal, Typhoon will return to home and remain in a hover until the signal is regained. Typhoon will land if the voltage is below 10.7 volts for a consecutive 3 seconds if the signal is not acquired.
• Improved GPS performance
• Improved Typhoon performance in wind
• Increased Angle Mode speed to 17mph
• Increased Follow Me and Watch Me speed to 22mph
• Improved landing characteristics
• Wizard connectivity
Make certain you select the right page for the downloads for your camera. Either the Q500+ or the Q500 4K. Also notice there is a ST10 and a ST10+. Most are the plus model.
Support Downloads
Wise choice there. Read the instructions 2-3 times and watch the videos. There are ways to mess this up but going a step at a time gets good results. Use fully charged batteries on both.so I am afraid to touch anything till next week.
