First Drone
New to the drone world. Flew RC planes years ago so hears to new adventures lol.
Question....I bought a Q500 that was advertised as never flown and I am curious to know if there is any way to connect the drone to a computer and see if it logs any sort of flight time? Thanks
Check the ST10+ Controller beneath the Battery and see if by chance the Owner Inserted and left a SD Memory Card. If so there might be the telemetry data on the card that would tell you some things.
Thanks I will check that. There was not an SD card in the camera so I will have to buy one. What size card does must folks use. Will a 64GB card hold much or should I go with a 128 or larger.
32 G class 10 for the ST- 10 is all you will need 64 G for the camera after you down load the files just delete them from the 64 G card the .the only thing i would recommend is buy a brand name sd card not one from china they seam to crash after 15 G .
Reactions: anix
costimarcos
