Flight Parser unavailable
Is this happening during normal flight or when you have set a CCC?
it happens when i call up the menu on the st16 and want to replay/view the file.
sometimes it crashes the app.
Reactions: Nuance
If you are talking about the Yuneec supplied apk that you get to in PAD mode.
On the top right corner there are 3 dots.
Select the dots and then select the other MAP. I think it defaults to Google maps.
See if that helps.
See if that helps.
Marvelous!!! did work, funny how something so stupid can change all!!
Thank you!
TroyBoy
