Galileo
Hello,
J live in EU, Can change m'y typhon Gps by
Galileo ??
Pat
Ce que vous voulez faire n'est pas clair.
Bien que la langue de base du forum soit l'anglais, il est parfois utile de publier à la fois en anglais et dans votre langue d'origine.
It's not clear what you want to do.
Although the base language of the forum is English, sometimes it is useful to post in both English and your original language.
The GNSS module of Typhoon H has GPS chip MAX M8Q. This chip can process signals from GPS (QZSS), Glonass, Galieo and BaiDou. It can use 3 of them at the same time. It says the Typhoon H FW activates only GPS (QZSS) and Glonass. To change this you need a new firmware for the flight controller. We will never get...
On the other hand it makes no sense to change GNSS operator because all working worldwide.
Reactions: DoomMeister
If the owner plans to use the bird in the "red" zones on the map, better is to not hope for GPS more than ever for GLONASS.
Unfortunately, this drone is not the best choice for long-term use in this situation. Very open communication protocol, freely readable operator's position over the air, and so on.
Ludwig
