geo-fencing
Gulfport, MS
I'm using the, "H," for work and the geofencing has been removed. I was checking in an area that I have an airspace authorization, but the "H," would go no higher than 62-feet. Is there something that I'm not doing correctly?
How did you remove the geo-fence? Have you adjusted the height in the GUI? Are you flying in Angle mode?
Do you have a commercial waiver? If you have an amateur waiver that's as high as you can go. Some limits are retained with the hobby waiver in certain areas.
If you did not submit a copy of your 107 license with the waiver application you have an amateur waiver.
Reactions: THoff
Sierrarhodesss
