I know, I was kidding on the 32 minute waypoints. Actually whomever setup the displayed waypoint flight did it in haste. tHEy need to go back into the general settings and change from meters to feet, and Km/h to MPH. I know the area tHEy setup to fly out by the California/Nevada state line. I also know the waypoints in the posted image haven't been individually adjusted to show camera pitch or yaw, if tHEy had, the waypoints would have the white cresent on the waypoint itself. Good demo screenshots wonder how @Rayray got them? ;P I think he knows a guy or two.Sweet!
Exactly what I am looking for. User selects altitude and overlap. App determines grid, based on camera and chosen parameters.
For Bob529 (32 minute waypoint flights): I will! Read: mapping, visual and thermal.
Anxious to get my hands on this bird. May have to wait though and let everyone else have the excitement of the first flights.
Due to the change in flight controllers and difference in the airframe it is highly unlikely DataPilot will be compatible with the TH.
i would say we have a firmware update coming soon to all the st16s out there .
as there is no 520 model to choose from . i dont see them making a 3rd st16 just for this bird .
Is this just a speculation or do you have anything to back this info up?
There is a $10 APP which allows battery swap midway in the map making process called Maps Made Easy it returns to where it left off and finishes the map....I'm wondering once you've shot the files on the 520 if they offer anything to assemble them. PhotoScan is a couple thousand dollars and Pix4D is $4000 last time I checked for doing that task others do assembly whereby you pay by the job via the web. I've used Photoscan with Maps Made Easy for orthographic mapping which turned out pretty nicely.I notice battery swap. Yuneec seems to have covered quite a bit with this new DataPilot.
Not much need to speculate, why would they provide $3,000. Drone tech for a $1,000.00 drone? You don't make money selling new product that way. Toss in the 520 is designed around commercial applications, not amateur/semi pro consumer application and there's even less reason to make software backwards compatible with different hardware.
Am I interpreting this correctly from the Yuneec website?
Thoughts?
Precise and efficient flight plans
Yuneec DataPilot™ software system enables users to efficiently and consistently create orthomaps, 3D scans, crop data imagery, in the field or on the desktop for repeatable, recallable aerial flight paths, without requiring expensive third party software.
It refers to giving you the tools so you can schedule flights and then get orthomosaic or whatever you want. "Precise and efficient flight plans" and "for repeatable, recallable aerial flight paths" How you process the images you get is up to you. That's how I understand it........................................ The truth is that it is ambiguous and gives rise to interpretations, we have less left to know
