H520 Released????
Interesting to see mention of the A-20 charger with the 520. The 480 came with the SC4000-4 charger. I can't see any info online about the new charger and specs - wonder if it will do more than just charge a LiPo??? Discharge and storage would be handy.....Battery specs when connected would be even better.
The a20 is basically a hitec x2 AC/DC smart charger. Can do storage etc. I presume also LiOn for the ST16S controller.
H520 now for sale on Vertigo drones with all new cameras and combos
www.vertigodrones.com
Still listed as on a pre-order...says delivery in July. If the TY pre-order history is anything to go by, then read 'delivery in July' as sometime later this year;)
So.. on the. "Will the H520 battery fit the H480?"
Here's a thought.
What if they are just using a larger capacity battery?
The current H480 battery is 5400mAh
This one "YUNEEC TYPHOON H 8050MAH 4S, 14.8V LIPO BATTERY" is now available on eBay.
So using logical mathematics
Current flight time 22 minutes
Current capacity 5400
22/5400 = 0.004074074074074
0.004074074074074 x 8050 = 32.79 minutes
That's my 2c.
Would be nice if the battery is the same especially if you just bought one of those expensive 4 port H battery only chargers.
Using the same battery chemistry, to substantially increase the capacity the dimension usually increases as well. That a Tattu 6300mA battery is exactly the same dimension as the Yuneec 5400mA battery suggests one of them is mislabeled.
If we look back a little we see that Q500/Typhoon batteries did not fit the Chroma or the H. Interesting part is that the Q500/Typhoon battery was the same voltage and capacity used in the Chroma but cased differently. The H battery became a 4s instead of 3s. I'm pretty sure the 520 battery won't fit the H.
marcojanson67
