H520E Arm Replacement
Hi All.
Are there any great instructional videos to help me replace an arm? I see an arm replacement video for the Typhoon H, will this be the same process?
Thanks in advance for any help.
As far as I know, the airframe has not changed compared to the Typhoon H+ and H520. So every Video about those will work for the H520E as well. The Typhoon H is also pretty similar so that a video will help a lot and might even be enough to solve your issue.
Thanks! That is what I had hoped.
Not a lot of repair support in Canada...
Yeah, I hear that! Of course, it had to be an arm with an antenna. I successfully replaced the arm, but required the landing gear and speaker box component to expose the antenna connection.
Although pretty nervous, it was not that bad and followed up with a successful test flight!
dq745
