Hard crash. Need help.
NYC
Hello friends!
I crashed my drone. Hard and nasty.
It seems to be fine (tbe plastic body is broken, but it is not a big deal). But I have thd problem with the camera.
It works, I can start it, connect to the controller and receive the picture.
YAW and ROLL motors are working.
But the PITCH (vertical camera movements, directing by the controller) doesn't.
I disassembled the camers, and tbe frame looks deformed at the right side (bearing side). Pictures are attached. The camera moved absutely free and smooth, and tbe frame as really hard, so I can't believe that it has been deformed because of the crash, but it loks strange.
Any ideas? Is this shape of the frame is OK?
When can I find tbe problem?
Alex, FYI, I do not see the pictures you attached. The only help that I might offer is to reinstall your firmware and see if that helps. There are people on this forum that are much more knowledgeable than myself and I hope that they can give you a better insight.
I don't see the pic either, but does the pitch work for stabilizing and just not respond to the controller, or does the pitch not work at all?
I found the problem. The plastic axle is broken. It was not visible at tge first look. Looks unreparable :/
Smyers
