Help camera anchorage
The camera has 4 points anchorages after the drone, and I have1 which is off! How i replace it?
Please im discouraging, need your help or link or video please
There are several ways. Last night I installed some new ones and I used a long thin rubber band. I made a loop around the top flange of the damper and fed the other end of the rubber band through the hole and then just pulled it into place. You have to remove the camera from the H and then remove the black plastic cover on top of the gimbal.
Here is a good method as well.
Digicrusader
