HI guys can anyone point me in the right direction in regards to fixing my Typhoon H after it all of a sudden lost gps and doped out of the sky,
was on full battery both drone and st16 controller, I have fixed structural breakage's with a couple of new arms and new gps module.
and now for some reason I cant connect to the cgo3 after this crash, I have pulled the cgo3 apart to checked for any damage, it looked fine, I pulled the
connector plate from the drone to cgo3 off and checked the contacts, they were good, not damaged or pushed in, I pulled the carriage apart for the
mount between drone and cgo3 check for damage or loose wires, that looked good,
Have tried many of the fixes from factory reset and reinstall with no success, when uploading the software again the st16 controller updates fine both with
micro sd card and wifi, the Aircraft and cgo3 I cant install and software either via sd card ( it wont even detect the sd cards there to update or (wifi it says wifi is disabled, update failed), every time I go back and re-connect to wifi, I then go back to the main screen and the wifi disconnects every time so I dont know what is going on with that ??
The green light is off on the camera, the camera goes through the motions on start up and positions it self facing to the right instead of directly front, camera just wont start up or connect
cant get aircraft or cgo3 to show up on bind screen ???
Help needed in Australia
Thanks Guys
Thanks Guys
