- Joined
- Oct 27, 2017
- Messages
- 424
- Reaction score
- 376
I have been having a discussion with Steve Carr about some ideas I have upgrading and downgrading the H Plus.
Well today I took the plunge knowing there were vibration issues with the latest firmware to basically see if I could get out of the mess if I had the vibrations.
I did it and now I am totally screwed because of the stupid idea of OTA updates only. Note to self to not bloody tinker ever again.
I have just updated my H Plus to the latest firmware dated 0108 version 1.10 and build number 743
If you are in Europe and have an H Plus DO NOT UPDATE TO THIS FIRMWARE.
The gimble has an uncontrollable vibration affecting the camera when facing forward at zero degree. It now makes taking any video of any form useless until a firmware fix comes out. When facing downwards the vibration goes.
In the Yuneec forum this has been mentioned by most of the users on E firmware. If you are on C firmware for example anywhere in the world except Europe this problem does not exist.
Now being a kind of guy that likes to have a tinker I decided to upgrade to see if there was a way to downgrade if there is a problem. I own a 520 and E90 also and upgrading and downgrading is easy if there is an issue using .bin files to over ride the current settings. The C23 camera firmware is not a .bin file but a .yuneec executional file, therefore it does not work by inserting the file and changing its name to a .bin onto an sd card and inserting it into the C23 camera. This form of updating by only OTA is a complete joke and has now rendered my H Plus unusable and will most likely have to go back to yuneec to be fixed. Unless someone has the standalone .bin file for the C23 which I suspect no one has as its not been put out to download.
Also note on the screen of The ST16s that the drone is 60m away from me dropping to 38m when its about 20cm away from me.......Please Yuneec dont make this another complete cockup like the H520
Here is a link to a video showing the problem.
