- Joined
- Oct 23, 2016
- Messages
- 77
- Reaction score
- 5
- Age
- 75
Thank for taking the time to respond. For real estate shots and nature, I move very slowly, at low altitudes. 3 or 4 make 6 feet or so. When I change direction from a stop even with the Phantom, it greases it. On the Typhoon even with a wicker tweak, it jerks. I am hoping (and I'm optimistic) that between this forum and Yuneec, it'll get dialed-in. With making professional diode a jerk is not acceptable. Even for met own stuff it isn't.Drifting a foot or two is pretty good for any drone. My Typhoon H drifts now and then at low altitudes but I just snap it back in place and then it behaves (it's not a concern to me at all). You'll never get the Typhoon H to behave like the Phantom & vice versa.
I'm wondering if the jerking motion you speak of is what some would consider normal. Since the craft has six blades and can look long with the landing gear down, it will look as if there is more tilt movement than a Phantom 4 would give when moving in any horizontal direction. Of course, once you are flying in any direction all should be smooth until you stop or abruptly change direction.
Check out the two photos below. These are snapshots taken from a video I was putting together on a fun day flying. In the first one with the Typhoon H, you would think it was moving to the right, but actually I was slowly moving it to the left and when I released the sticks it tilts in the opposite direction for a fraction of a second to stop all movement. The photo of the Phantom 4 Pro is exactly the same but I moved it in the opposite direction... I moved the Phantom 4 Pro slowly coming in from the left and then released all sticks.... it tilts very little and tends to control itself differently than the Typhoon H (possibly due to weight, size, balance points & having only 4 very large blades). The Phantom 4 Pro does not have the appearance of jerky movements at slow speed.
