LED Status, solid purple, slow blinking white (looks like white)
Could it be blinking yellow? No cam card or card full.
Is solid purple Angle mode with GPS or IPS?
Good luck.
No ! Manual says : The Aircraft is in Angle Mode with GPS or IPS lock = LED Glow solid purple !!.
More possible are that's in Angle Mode , loosing GPS signal for some reason!
This is from the manual I recently downloaded, is this correct?
I receive yesterday my second H with Intel sense, production end of September, I charge the battery and Fly's out of the Box perfectly ! , without need to calibrate anything!.
But the manual no explain this solid purple and white blinking nowhere! And supposedly it is the newest manual!.
Reactions: anthony h-ellary
Please call customer service and they will tell you the same thing we have told you. The manual has not been updated. Watch any of the youtube videos of the Typhoon H and you will see that this is normal.
Oh, and you should calibrate any new drone.
Resolved, the Yuneec H is equipped with Dual GPS system and when it show's a white blinking some time in solid purple, means that he receiving signal from
Russian Satellite system Glonass!.
Reactions: smokinram
Which country are you in, Doc?
Spain, another 3 times orange blinking are not explained in the manual! when it shows this that's mean the "H" like to be compass calibration! .
Also not dead calibration your "H" !.
LED STATUS DISPLAY ON
Main LED status indicator
LED STATUS INDICATOR BEFORE / DURING FLIGHT
- The Copter is in Smart Mode with GPS signal
- The Copter is in Home Mode
- GPS
LED status display below the motors
LED STATUS DISPLAY OF THE CALIBRATION MODES
- Mode selected to calibrate the compass
CGO3 + CAMERA A LED STATUS INDICATOR
- No SD card or SD card memory full
- WiFi error
- WiFi connection
Flashes quickly red and white (5 times per second)
Flashes red, green, and blue every 3 seconds
Blinks purple (1 flash per second)
Flashes fast (5 times per second)
Flashes slowly red and green (2 times per second)
Flashes yellow
Flashing red
Blinks green
Blinks slowly green and blue
LED STATUS INDICATOR V1.1
- The Copter is in "Binding" Mode
- The Copter is in a flight ban zone *
- The Copter is in Smart Mode without GPS signal
- The Copter is in angle mode with GPS signal
- The copter is in angle mode without GPS signal
- First stage of warning of empty flight battery
- Second stage of warning of empty flight battery
- Warning of empty flight battery
- Calibration of the compass started
- Mode for calibration of the acceleration sensor
- Calibration of the acceleration sensor started
- WiFi
Flashes red, green and blue (2 times per second)
Pulsed red (3 times per second)
Flashes very fast orange (10 times per second)
Blinks green (3 times per second) then off (for 1 second)
Blinks purple (3 times per second) then off (for 1 second)
Flashes fast red (5 times per second)
Blinks slowly green and purple (1 time per second)
Flashes fast red and green (5 times per second)
Flashes slowly red, green and blue (1 time per second)
Flashes fast red, green and blue (3 times per second)
8 13646 02500 5
YUNMA000029
- The Copter is in Smart Mode with GPS signal and GLONASS
- The Copter is in angle mode with GPS signal and GLONASS
Lit continuously green and flashes white (for 1 second)
Lit permanently purple and flashes white (for 1 second)
- The Copter requires a compass calibration Blink orange (3 times per second) then off
- OBS active LED under front engines flashing white (1 time per second)
Hey whats up doc? Someone on this forum posted an updated chart that I believe they put together and it's accurate. The chart that ships with the H isn't accurate as others have stated. I fly with purple and white. None of us can understand why Yuneec hasn't updated the chart, It's kind of a bad joke at this point. I thought orange flashing was that you needed to bind the tx to the H?
Ludwig
