motor problems
any member of the forum that knows if there is someone in Puerto Rico who repairs a typhoon h ??? I have problems with mine...fifth motor mode
Are you getting this on the ground without props?
The best way to check your motors is to run the Typhoon H GUI on a Windows PC and connect the Typhoon H using a data capable USB cable.
If your using the Typhoon H GUI to Test the Motors with the Propellers Removed, the Motors will sound Strange, also check for loose Screws that may Stuck or Lodged causing the Motor to Seize or Lock. Remove the Motor Mount Bolts and Inspect it Top & Bottom.
Patynowy
