My ST10+ is no longer responding (charging)
Hello together
When I wanted to charge my remote control (ST10+) this morning I notice no reaction from the remote control. It has not loaded. I then wanted to turn on the remote control but nothing worked anymore. What should I do?
Hello.
Have you tried to leave it plugged into the charger for a few hours?
It could be that the battery is completely discharged and needs some time to reach a minimum level for wake up the transmitter.
Before doing so, it would be good to take out the battery and check its voltage with a multimeter, then report the results here.
Reactions: 7cyclops
If the boot partition is changed or destroyed the trickle charging will not work too. Better is to measure the battery voltage first.
Reactions: 7cyclops
bancadoithuongads
