hiEven if they added the wifi frequency selection, I cannot figure out how to select it.
you can select wifi indoor or outdoor frequency under the settings cog.. not drone or cam settings the cog settingEven if they added the wifi frequency selection, I cannot figure out how to select it.
i update my firmware earlier and never updates fully i get error message so had to do reset for it to work it shows that i have the latest 1.1.9 it always does this when i update any new fimware on the breezeThanks, I've found it after updating also the breeze firmware.
Basically you can set if you want the breeze to use 5 ghz wifi indoor or outdoor channel.
It changes the frequency. I suppose because not all the phones are supporting the higher channels. See attached image
Also it takes at least 1 minute to find the breeze on my phone but always does find it even if it takes a long timeThanks, I've found it after updating also the breeze firmware.
