Considering that many users, especially in Europe, have had enough serious problems with the latest firmware update (3.0.1 b27) yuneec wanted to know when it comes out again, which was announced in December. Do something please.
Other than some variance in the barometer roughly 122m or 400' is the ceiling in the firmware (at least in the United States) which can't be changed in the GUI. You may change it but the ceiling is still there. You need to sign a waiver with Yuneec. If they approve it you will receive a 'Special' firmware with the ceiling cap removed.I spoke to Yuneec last week and they said that B28 may be released this week. No mention of H firmware though, just ST16. I still have altitude problem where i cant go above 119m even after changing altitude levels in GUI.
Yuneec UK say it is a fault with the firmware which will be fixed in the next release. It is only a problem since B27.Other than some variance in the barometer roughly 122m or 400' is the ceiling in the firmware (at least in the United States) which can't be changed in the GUI. You may change it but the ceiling is still there. You need to sign a waiver with Yuneec. If they approve it you will receive a 'Special' firmware with the ceiling cap removed.
yes when you land it lands soft when you let off stick to push shut down on props it revs back up on the rear motors like its trying to level itself but pushes all the way till it turns overThis happens even when you hold the left stick all the way down for 3-5 seconds after landing? I have had nothing but gentle landings on the latest firmware.
Mine does that to unless I keep holding the stick down. Eventually you hear a change in the motors where they go to an idle state. At this point I can take my finger off the stick and press the red arm/disarm button to shutdown. Yours doesn't do that?yes when you land it lands soft when you let off stick to push shut down on props it revs back up on the rear motors like its trying to level itself but pushes all the way till it turns over
when i hold down stick it goes to idle but before you can push red button they rev and flip it foward and nothing like this or even flyaways happened till this last firmware update.dont get me wrong i love my h but they have to get this stuff straightened out i called support asked for a reboot file to start over they just want me to send it inMine does that to unless I keep holding the stick down. Eventually you hear a change in the motors where they go to an idle state. At this point I can take my finger off the stick and press the red arm/disarm button to shutdown. Yours doesn't do that?
good luck .people are doing all recalibrations .i even recalibrated st16 and still has issues .for mine to fly flawlessly anwith every update till last one its the firmware. glad i bought insurance incase it crashesHad easily updated without issue, and the combination is working perfectly, I'm unable to find any flaws. People need to also recalibrate all systems - compass, camera , etc. After the firmware upgrade.
I've owned my H since July and two times mine behaved in this way.yes when you land it lands soft when you let off stick to push shut down on props it revs back up on the rear motors like its trying to level itself but pushes all the way till it turns over
State farm sells it $75. A year or if you have auto or home they just add $6. A month to your billso far, all I've found is liability insurance. Does yours cover your UAV? If so, what all is covered, where'd you get it and how much does it cost?
