New firmware alive
Firmware can improve cameras in the following way.
  • Improve focus speed, image stabilization, speed of operation.
  • Correct problems with focusing accuracy, white-balance and metering.
  • Add customization options (new options for buttons and dials via the setup menu).
  • Add functionality like increase EC range, greater range of manual controls.
It's fixed focus isn't it ?????
I did the update of TYH 2.21a everything is ok.
Not possible to do the update in version 1.23 of the ST16 . " Unpack failed" someone has an idea ?
J'ai fait la mise a jour du TYH 2.21A tout est ok.
Pas possible de faire la mise a jour en version 1.23 sur la ST16. "Unpack failed" quelqu'un a une idée ?
OK,
I've installed the (European) version of the firmware and had a quick flight. First impressions are good - camera connection was no faster than the previous update (under a minute), but the connection did not drop (including raising and lowering the landing gear). The D-pad controls for the camera are very effective (will take a little bit of practise until muscle memory learns the right direction for EV/WB adjustments), and the trim controls work - handy for controlled pans and zooms.
Early impressions of video quality are also good. I'm sure it's psychological, but the Auto settings seem a little less extreme. It's purely anecdotal, but in one test video the recording reached 56Mb/s, just to please the bitrate crowd.
In other news, the Android version doesn't appear to have changed, but they have enabled screenshots for any app - hold down the Middle '|==|' button under the screen for a second or two. Screenshots are saved to /Pictures/Screenshots.
Reactions: Brent D
Lots of hackers in China.
What better way to make Yuneec look bad than DJI employ hackers to mess with the Yuneec products.
(Just a thought.)
If this was a hack then Yuneec better let them have at it more often!
Was hard to bring ST16 up to the newest FW Version, had do do it several times "*!%*ç"?
Now is a problem: OBS Avoid is not possible, Real Sense Modul installed switched on in the settings. Find it in the new ST 16 Manual:
http://download.yuneec.com/Typhoon_...16_Firmware_Update_Version_B23_What's_New.pdf
If Realsense Module is installed, please update to the latest version. And select RealSense
module installed in other settings.
With sustainable GPS signal, RealSense can be activated. The range meter will indicate the
distance between aircraft and obstacle, and give out a warning alert meanwhile.
Wich camera to select in the H Model ?
C-G03
C-GO3 Pro
C-GOET
hint: I just find out, that you don't need a micro sd card to update the st-16:
It's also possible to copy the update file directly into the root of the internal flash of the st-16 via usb-cable.
No trouble with the format of the micro-sd card any more :)
And it's even a little bit faster while installing :)
I have not performed any updates at all since i purchased unit 07/19/16
I have watched the tutoriala but have a question. Do i need to update the st 16 first or does it not matter.
Thanks
Reactions: Dabbler90
TyphoonH_Ver2.21_A (and E+J+F) + ST16_V3.1.23.yuneec
standard H http://download.yuneec.com/Typhoon_H/TyphoonH_Ver2.21/Standard/TyphoonH_Ver2.21_A.bin
euro H
http://download.yuneec.com/Typhoon_H/TyphoonH_Ver2.21/Europe/TyphoonH_Ver2.21_E.bin
japan H
http://download.yuneec.com/Typhoon_H/TyphoonH_Ver2.21/Japan/TyphoonH_Ver2.21_J.bin
Australia_New_Zealand H
http://download.yuneec.com/Typhoon_...Australia_New_Zealand)/TyphoonH_Ver2.21_F.bin
China H
http://download.yuneec.com/Typhoon_H/Typhoon+H+special+for+CN/TyphoonH_Ver2.20_A.bin
updated ST16 (ready official release in china 下载 - Yuneec)
http://download.yuneec.com/Typhoon_H/ST16/ST16_V3.1.23/ST16_V3.1.23.yuneec
whats new (eng)
http://download.yuneec.com/Typhoon_H/ST16/ST16_V3.1.23/ST16 Firmware Update Version B23 What's New.pdf
http://download.yuneec.com/Typhoon_H/ST16/ST16_V3.1.23/ST16固件升级B23 What's new.pdf
im not employee and not dev team :) (just the user Typhoon H)
update at yours own risk :)
my H is euro updated with standard:) and
after update can`t connect with H go right-down corner setting switch to team mode , go system setting refresh and will find now H to bind :)
Returning home alt. - Nice
Downloaded both the standard versions of the ST-16 zip file and H firmware zip file. Copied the ST-16_V3.1.23 file to a sd card and the ST-16 doesn't recognize it. Ideas? I didn't think you had to extract the files first as it should read the SD card right?
OneIndiaPestControl
