Hi all,
Had a problem with my rebuild on Typhoon H Pro, I lost the bay with the shell bolts in it ,,, !!
Must do a really good work bench and floor clean,,, some day BUT as you do I thought what else would fit ,, omg the battery bolts to the door latch end, for the Q500 4k, are just 1 screw turn short so what the hay i will test a couple... blow me down they work plus I also found the main spar from the motor to motor also has the same bolts ?.
So shell is on A ok, and just did mini flight out side and no problems ?.
Went to Yuneec dealer in Europe to see how much the bolts are to replace on Q500 4K and €7.79 with latch and battery box holder ?.
I found it under " Q500 4K Battery Frame and Door Set ".
So if you ever lose 1 or 2 you know were to go.
T ??
T ??
