Quiet propellers
I would like to put “quiet propellers“ on my Yuneec Mantis Q. Can I use any of the other propellers that I see advertised? Are the prop connections universal or does each brand have its own way of mounting propellers?
There are many aspects you have to mind when choosing a propeller like mount, pitch, diameter, stiffness and so on. You cannot simply use another propeller espacially with these consumer drones, which cannot be modified a lot. Usually there are some alternatives but most of them have a pretty poor quality. As far as I know there is nothing outthere, which I can recommand for the Mantis.
Like @Mrgs1 said it usually ends up pretty bad when using non OEM propellers. I personally had very bad experiences with the Typhoon H (one major incident and one crash). Both times cheap non OEM propellers broke midair without any apparent reason.
Reactions: Rickbat
People that build their own drones have access to the software settings (PID - proportional, integral, and derivative) that control the ESC’s supplying power to the motors. When propellers are changed on a system those settings have to be matched to the system in order for the drone to react properly and protect the motors from overheating or stressing the ESC drivers.
Reactions: Rickbat
Thank you very much for your input!
xbytesolution
