If you are using the ST10+ that came with the Q500 then use a MiniSD Card of 4 or 8 gig size and it can be a slow cheap card even the card that came with the craft. If it is in the controller then all your telemetry data will be recorded to it and can be retrieved later. You can use the Battery Charger Cable and plug the controller into your computer to retrieve the data from the card.What's this I hear about an SD card in the controller, under the batteries? I didn't even know about that until reading on this site. How do I use that? How do I read those files too?
