st 16s controller file clean up
I do not have a ST16S but two ST16 and a ST10. I think it is similar for both. Maybe path names could be different.
I connect it to my PC via USB cable. Then I open the file manager and manage the files ;-).
Regularly I do the following:
- Copy the whole folder "FlightLog" (or Flight2Log for H plus) to the PC in my log archive. I rename the folder with a date/ time mark to avoid overwriting the archive with later files. Then I delete the whole flight log folder on the ST16. It will created automatically at next flight. The encrypted Flightlog I let untouched but if you want to make all clean you can delete it too.
- I check and delete all *.mp4 and picture files from video-downlink in folder /flightmode/media_data
- Copy all screenshots (if there some) to my PC and delete it on ST16. Screenshots are here: /Pictures/Screenshots
There are a lot of empty folders and some folders that belongs to the system (/Android, /logs, otLogs and so on). Let it untouched.
Edit: The pictures in folder /ModelsIcon should keep untouched.
Ludwig
