It is capable of only displaying video feed from the CGO3+. If you are able to produce such video stream via WiFi, it its very likely to show it. In case of Boscams / other analog transmitters, you need to convert it first to digital, then encode it similar to CGO3+'s stream, and then stream it to the ST16 like the CGO3+ does it. It is possible to do if you want, but it will require some work with Linux and FFMpeg/GStreamer etc. In the photos is my larger drone which transmits video to ST24 via Yuneec's Mk58 transmitter. Unfortunately the Mk58 is -not- compatible with ST16.
