St16 v1.
The team mode has worth to be investigated too. Better is now than later, due to use the same experimental base.
Hold in mind, the SR24 has been informed of what will be connected in the power-up stage of the ST16. If you change the model you should restart the ST.
Good point, yes I will do. I switch off/on the ST16 very often in order to download telemetry to compare with what I have sent.
All I have and also a new version of the test tool is here:
ZigBee sniffer will be the best of your friends. It has online export to a terminal. A suitable one is YAT. After that you'll have the up and down streams to analyze, The good point will be to prepare some parser of this stream. On the Pi of course. This will be the starting point to my old dream to have a secondary telemetry display on the ST16 ;)
ZigBee sniffer will not help. ZigBee is only the transport protocol. What comes out depends on SR24 firmware and what drone and controller firmware defines. The data format is pretty clear now. I can see the channel data on the Pi and I can send valid telemetry, faking a drone.
Reactions: Pöllö
At least on the ST16 side, the sniffed data from the air is the same as sniffed via the wires. Take a look at our private conversation from the last year. There I have sent some pictures together with the "names of the fields".
FYI, to try to get the SR24 receiver firmware I tried capturing the serial data sent to the SR24 while doing the FC firmware update to v1.35 from the Typhoon H GUI. No data was sent to the receiver during that upgrade. Maybe there just wasn't a receiver update in this version.
Maybe the receiver is never updated outside of the factory? On the ST16 it lists the TX version I think, but not the RX.
Dylan
That's awesome and very nice to see, congrats! ;) If you need any help with the telemetry or something, please let me know and/or take a look at the Thunderbirds' code. I reverse engineered the telemetry and its fields for that one once. ;) I am going to push its latest sources to git as it seems that it's working properly? ;)
Late is better than never... ;)
And here I am - even more late! ;)
Here you can read about the custom firmware for Typhoon, where the serial protocol is used and developed further based on existing PX4's implementation.
Try to disconnect it from the Pi, not to power down only. Probably you feed it via RS232 via some internal circuit in the SR24.
Do you put the receiving side in binding mode? I don't know the sequence for this, because especially the drone side is out of my interest, but I guess some happens when the copter blinks orange. You can sniff what is in the air at this moment with a ZigBee sniffer.
Here is how I do the binding in the Thunderbird firmware:
Have you managed to find out what's the difference between the receiving SR24 on the drone, and the transmitting one on the ST16?
If you want to ditch the ST16 and SR24, the Thunderbird, being very close to the stock PX4, could let you use any RX or suitable UART radio link/modem with the Typhoon. Currently its latest version is modified so that it accepts -only- SR24 as I had difficulties with some of PX4's code an year ago regarding radio scanning and locking, but it could be also compiled with "stock" PX4 receiver support, or we could write something more fancy for it if required. ;)
At least the speed is different. I never tried to listen from the drone side, because my ideas were pointed in two directions:
1. To add a secondary telemetry panel to the ST16 like in the ST24 FPV mode and to inject the drone position in the Google Earth pro. For example, for me is very important to know the position of the ST16 and the quality of the received GPS signal.;
2. To sniff the link between the camera and the drone for further development of the ID and telemetry transmitter when this will be requested from FAA, EASA, Mars aliens and so on.
Both points were successfully engineered but only this was done. I'm not a coder so I usually asking someone to give some help in the implementation of my ideas. Helmut did some good tasks for me and I very much appreciate his help.
Really, in the camera<>drone communication I found a strange device, numbered as 5, which is still a mystery for me, but this is not so important. All the rest is more or less clear.
One more idea was to change the SR24 in the drone with a 4G modem and autonomous movement with fake GPS data in the follow-me mode. Probably this is illegal in some countries, but "just for educational purposes" will be OK.
Some examples:
Sync Ln ???? Seq PAN Dest Src Rad Time Latitude Longitude Altitude Vx Vy Vz Sat Vbat Cb Roll Pitch Yaw M6 IMU B/C f/m vt Err GPS fsk CRC8
5555 30 8841 84 9616 46F1 8AC5 08 A603 6045181A AAFB230E 01000000 FCFF 0100 0900 0B 6C 00 A4FF F5FF 6F5D FF 61 55 10 05 00 2D E5 5C
5555 30 8841 C4 9616 46F1 8AC5 08 A803 6045181A AAFB230E 02000000 FCFF 0100 0900 0B 6C 00 A4FF F5FF 6F5D FF 61 55 10 05 00 2D E9 90
5555 30 8841 84 9616 46F1 8AC5 08 AA03 6045181A AAFB230E 02000000 FCFF 0100 0900 0B 6C 00 A4FF F5FF 6F5D FF 61 55 10 05 00 2D E5 48
5555 30 8841 84 9616 46F1 8AC5 08 AC03 6045181A AAFB230E 02000000 FCFF 0100 0900 0B 6C 00 A4FF F5FF 6F5D FF 61 55 10 05 00 2D E9 47
5555 30 8841 C4 9616 46F1 8AC5 08 AE03 6045181A AAFB230E 02000000 FDFF 0000 0B00 0B 6C 00 A4FF F5FF 6F5D FF 61 55 10 05 00 2D E4 4E
5555 30 8841 84 9616 46F1 8AC5 08 B003 5645181A AFFB230E 02000000 FDFF 0000 0B00 0B 6C 00 A4FF F5FF 6F5D FF 61 55 10 05 00 2D E5 8B
5555 30 8841 84 9616 46F1 8AC5 08 B203 5645181A AFFB230E 03000000 FDFF 0000 0B00 0B 6C 00 A4FF F5FF 6E5D FF 61 55 10 05 00 2D E9 E0
Sync Ln ???? Seq PAN Dest Src Rad Thr Ail Ele Rud FLM RTH CAv CAh CAT CAP LDG AUX Latitude Longitude ???? Acc ?? Alt Speed Angle Sat ???????? CRC8
5555 32 0000 C4 88F2 5C3E B82A 31 800 800 800 800 800 800 29D 802 888 2AB 0 4 9736181A DF1E240E 0000 6C 42 1A00 0000 7A00 09 00000000 A2
5555 32 0000 C4 88F2 5C3E B82A 31 800 800 800 800 800 800 29D 802 888 2AB 0 4 9636181A E71E240E 0000 6C 42 1A00 0000 7A00 09 00000000 7C
5555 32 0000 C4 88F2 5C3E B82A 31 800 800 800 800 800 800 29D 802 888 2AB 0 4 9636181A EF1E240E 0000 6C 42 1A00 0000 7A00 09 00000000 DE
5555 32 0000 C4 88F2 5C3E B82A 31 800 800 800 800 800 800 29D 802 888 2AB 0 4 9636181A F71E240E 0000 6C 42 1A00 0000 7A00 09 00000000 3F
5555 32 0000 C4 88F2 5C3E B82A 31 800 800 800 800 800 800 29D 802 888 2AB 0 4 9536181A 001F240E 0000 6C 42 1A00 0000 7A00 09 00000000 2D
5555 32 0000 C4 88F2 5C3E B82A 31 800 800 800 800 800 800 29D 802 888 2AB 0 4 9536181A 071F240E 0000 6C 42 1A00 0000 7A00 09 00000000 01
Use fixed font and tabs...
Some examples:
Hi,
That looks interesting! Could you tell me a bit more about that camera<- ->drone communication? I tried once to figure that protocol out while I was developing/modifying the bootloader for the Thunderbird/PX4 to start up the gimbal, but could not figure it out. At first the CGO3+ expects a certain PWM sequence, which after it goes to some weird one wire communication which is used for some purposes and firmware transfers.
Br,
TR
Here is my implementation of transmitting telemetry data from the Thunderbird if this helps anyone:
C++:
//Alignment/padding
        #pragma pack(push, 1)
        typedef struct {
                uint8_t length;       ///< length includes type, data, and crc = sizeof(type)+sizeof(data[payload_len])+sizeof(crc8)
                uint8_t type;       ///< from enum ST24_PACKET_TYPE
                uint16_t t;     ///< packet counter or clock
                int32_t lat;      ///< latitude (degrees)  +/- 90 deg
                int32_t lon;      ///< longitude (degrees)  +/- 180 deg
                int32_t alt;      ///< 0.01m resolution, altitude (meters)
                int16_t vx, vy, vz;     ///< velocity 0.01m res, +/-320.00 North-East- Down
                uint8_t nsat;     ///< Sum of GPS status and number of satellites.
                //GPS status is bit 8 of the byte. Number of satellites is defined using the first 5 bits.
                //0b10011111 = GPS Ready, 31 satellites.
                //0b00011111 = GPS Acguiring, 31 satellites.
                uint8_t voltage;    ///< 25.4V  voltage = 5 + 255*0.1 = 30.5V, min=5V
                uint8_t current;    ///< 0.5A resolution
                int16_t roll, pitch, yaw; ///< 0.01 degree resolution
                uint8_t motorStatus;    ///< 1 bit per motor for status 1=good, 0= fail
                uint8_t gpsStatus;    ///< gps and obs status
                /* Example: 0x61
                * 0x[X]Y
                * 0001 yyyy = gps disabled, obs rdy
                * 0010 yyyy = gps acquiring, obs disabled
                * 0100 yyyy = gps disabled, obs disabled
                * 1000 yyyy = gps disabled, obs disabled
                * 0xX[Y]
                * xxxx 0001 = none
                * xxxx 0010 = none
                * xxxx 0100 = none
                * xxxx 1000 = none
                uint8_t obsStatus; ///< obs_avoidance | unknown
                /* Example: 0x55
                * 0x[X]Y
                * 0001 yyyy = obs avoidance fail
                * 0010 yyyy = obs avoidance fail
                * 0100 yyyy = obs avoidance disabled
                * 1000 yyyy = obs avoidance fail
                * 0xX[Y]
                * xxxx 0001 = none
                * xxxx 0010 = none
                * xxxx 0100 = none
                * xxxx 1000 = none
                uint8_t flightmode;
                uint8_t optionbytes; ///< drone model | flight mode
                /* Example: 0x0510
                * 0x00XY (Bytes 0-1)
                * 0x[X]Y
                * 0001 yyyy = READY
                * 0010 yyyy = IPS
                * 0100 yyyy = "N/A"
                * 1000 yyyy = THR
                * 0x1[Y]
                * 0001 1000 = WATCH
                * 0001 0100 = RATE
                * 0001 0010 = MAG CALI
                * 0001 0001 = NO RC
                *0xXY00 (Bytes 2-3)
                * 0x[X]Y
                * 0001 yyyy = nothing
                * 0010 yyyy = nothing
                * 0100 yyyy = nothing
                * 1000 yyyy = nothing
                * 0xX[Y]
                * //xxxx 0001 = BATT RED, drone model: hex
                * //xxxx 0010 = BATT FULL, drone model: quad
                * //xxxx 0100 = BATT RED, drone model: hex
                * //xxxx 1000 = BATT RED, drone model: hex
                * 0x03xx = drone model: quad, batt red
                * 0x05xx = drone model: hex, batt ok <---- Typhoon H (captured)
                * 0x06xx = drone model: hex, batt red
                * 0x07xx = drone model: hex, batt ok <---- ?
                /* Provided by h-elsner
                f_mode (decimal)        Meaning                                Display
                0                       Stability mode (Blue solid)             THR
                1                       Blue flashing - GPS off                THR
                2                      Blue - GPS lost                         THR
                3                      Angle mode (Purple solid)              Angle
                4                      Purple flashing - GPS off              Angle
                5                      Angle mode (Purple solid)-GPS lost     Angle
                6                      Smart mode                             Smart
                7                      Smart mode - GPS lost                  Angle
                8                      Motor starting                         Start
                9                      Temperature calibration                Temp
                10                     Pressure calibration                   Pre Cali
                11                     Accelerator calibration                Acc Cali
                12                     Emergency/Killed                       EMER
                13                     RTH coming                             Home
                14                     RTH landing                            Land
                15                     Binding                                Bind
                16                     Initializing, Ready to start           Ready
                17                     Waiting for RC                         No RC
                18                     Magnetometer calibration               Mag Cali
                19                     Unknown mode
                20                     Agility mode (Rate)                    Rate
                21                     Smart mode - Follow me                 Follow
                22                     Smart mode - Follow me - GPS lost      THR
                23                     Smart mode - Camera tracking           Watch
                24                     Camera tracking - GPS lost             THR
                26                     Task Curve Cable Cam                   CCC
                27                     Task Journey                           JOUR
                28                     Task Point of Interest                 POI
                29                     Task Orbit                             ORBIT
                32                     Indoor Positioning System              IPS
                33                     Waypoints                              WAYPOINT
                uint16_t alarmbytes; ///< unknown | alarms
                /* Example: 0x5820
                * 0x[X]Y
                * 0001 yyyy = imu temperature warning
                * 0010 yyyy = compass warning (captured, uncalibrated compass attached)
                * 0100 yyyy = ?
                * 1000 yyyy = no fly zone warning
                * 0xX[Y]
                * xxxx 0001 = battery voltage low
                * xxxx 0010 = battery voltage critically low
                * xxxx 0100 = imu temperature warning (again?)
                * xxxx 1000 = ?
                * 0xXY00 (Bytes 2-3)
                * 0001 yyyy = ?
                * 0010 yyyy = ?
                * 0100 yyyy = ?
                * 1000 yyyy = ?
                * xxxx 0001 = ?
                * xxxx 0010 = ?
                * xxxx 0100 = ?
                * xxxx 1000 = ?
        } telemPayload;
        typedef struct {
                uint8_t header1;      ///< 0x55 for a valid packet
                uint8_t header2;      ///< 0x55 for a valid packet
                telemPayload payload;
                uint8_t crc8;       ///< crc8 checksum, calculated by st24_common_crc8 and including fields length, type and st24_data
        } telemData;
        #pragma pack(pop)
C++:
/* Send telemetry packet */
int RCInput::send_packet(int uart_fd)
        RCInput::telemPayload telemetryPayload;
        RCInput::telemData telemetryData;
                RCInput::uorb_update_topics();
                if (counter >= 65535) counter = 0;
                counter ++;
                const battery_status_s &bat = subscription_data->battery_status_sub.get();
                const vehicle_gps_position_s &gps = subscription_data->vehicle_gps_position_sub.get();
                const vehicle_global_position_s &gpos = subscription_data->vehicle_global_position_sub.get();
                const vehicle_status_flags_s &vsflags = subscription_data->vehicle_status_flags_sub.get();
                const vehicle_status_s &vs = subscription_data->vehicle_status_sub.get();
                const vehicle_attitude_s &att = subscription_data->vehicle_attitude_sub.get();
                //const vehicle_air_data_s &air_data = subscription_data->vehicle_air_data_sub.get();
                //Disarmed
                if (vsflags.condition_global_position_valid == 1 && vsflags.condition_home_position_valid == 1 && vsflags.condition_local_position_valid == 1 && vsflags.condition_local_velocity_valid == 1)
                        gps_status = 0b10000000; //GPS status READY
                        telemetryPayload.flightmode = 0x10;
                else
                        gps_status = 0b00000000; //GPS status ACQUIRING
                        telemetryPayload.flightmode = 0x08;
                //Armed
                if (vs.arming_state == 2)
                        if(vs.nav_state == NAVIGATION_STATE_STAB) telemetryPayload.flightmode = 0x01;
                        if(vs.nav_state == NAVIGATION_STATE_ALTCTL) telemetryPayload.flightmode = 0x01;
                        if(vs.nav_state == NAVIGATION_STATE_POSCTL) telemetryPayload.flightmode = 0x03;
                        if(vs.nav_state == NAVIGATION_STATE_AUTO_MISSION || vs.nav_state ==  NAVIGATION_STATE_AUTO_LOITER) telemetryPayload.flightmode = 0x21;
                        if(vs.nav_state ==  NAVIGATION_STATE_AUTO_RTL) telemetryPayload.flightmode = 0x0d;
                        if(vs.nav_state == NAVIGATION_STATE_ACRO) telemetryPayload.flightmode = 0x14;
                        if(vs.nav_state == NAVIGATION_STATE_RATTITUDE) telemetryPayload.flightmode = 0x14;
                        if(vs.failsafe == true || vs.nav_state == NAVIGATION_STATE_AUTO_RCRECOVER || vs.nav_state == NAVIGATION_STATE_AUTO_RTGS || vs.nav_state == NAVIGATION_STATE_AUTO_LANDENGFAIL || vs.nav_state == NAVIGATION_STATE_AUTO_LANDGPSFAIL) telemetryPayload.flightmode = 0x0c;
                //Emergency
                if (vs.arming_state == 3) telemetryPayload.flightmode = 0x0c;
                //Get pitch/roll/yaw values from the vehicle_attitude topic's quaternion
                Quatf q(att.q);
                Eulerf euler(q);
                telemetryPayload.length = 0x26;
                telemetryPayload.type = 0x02;
                telemetryPayload.t = RCInput::counter;
                telemetryPayload.lat = gps.lat;
                telemetryPayload.lon = gps.lon;
                //telemetryPayload.alt = roundf(frac(air_data.baro_alt_meter) * 100.0f);
                telemetryPayload.alt = gps.alt * 0.1f;
                telemetryPayload.vx = (int16_t)gpos.vel_n * 100.0f;
                telemetryPayload.vy = (int16_t)gpos.vel_e * 100.0f;
                telemetryPayload.vz = (int16_t)gpos.vel_d * 100.0f;
                telemetryPayload.nsat = gps_status + (uint8_t)(gps.satellites_used);
                telemetryPayload.voltage = (uint8_t)roundf((bat.voltage_v-5) * 10.0f);//    0x63; //hex
                telemetryPayload.current = 0;
                telemetryPayload.roll = (int16_t)euler.phi() * 100.0f;
                telemetryPayload.pitch = (int16_t)euler.theta() * 100.0f;
                telemetryPayload.yaw = (int16_t)euler.psi() * 100.0f;
                telemetryPayload.motorStatus = 0xFF; //OK
                telemetryPayload.gpsStatus = 0x61;
                telemetryPayload.obsStatus = 0x55;
                telemetryPayload.optionbytes = 0x05;
                telemetryPayload.alarmbytes = 0x0000;
                telemetryData.header1 =  0x55; //Header 1
                telemetryData.header2 =  0x55; //Header 2
                telemetryData.payload = telemetryPayload;
                telemetryData.crc8 = st24_common_crc8((uint8_t*)&telemetryPayload, sizeof(telemetryPayload));
                int packet_len = sizeof(telemetryData);
                ::write(uart_fd, (uint8_t*)&telemetryData, packet_len);
        return 1;
Wrong. The init phase is a pure RS232 translated request and response. To see the request the best way is to sniff it without the camera mounted. You will see something like this one.
STX LEN SEQ SYS COMP MSG PAYLOAD CRC16
ID ID ID
FE 05 00 01 00 00 00000000000001 446F
FE 22 01 01 00 03 000200000000000000000000000000000000000000000000000000000000000000000000 CB12
FE 05 02 01 00 00 00000000000001 FF6D
FE 22 03 01 00 03 000200000000000000000000000000000000000000000000000000000000000000000000 7427
FE 05 04 01 00 00 00000000000001 326A
FE 22 05 01 00 03 000200000000000000000000000000000000000000000000000000000000000000000000 B579
FE 05 06 01 00 00 00000000000001 8968
FE 22 07 01 00 03 000200000000000000000000000000000000000000000000000000000000000000000000 0A4C
FE 05 08 01 00 00 00000000000001 A865
FE 22 09 01 00 03 000200000000000000000000000000000000000000000000000000000000000000000000 37C4
FE 05 0A 01 00 00 00000000000001 1367
FE 22 0B 01 00 03 000200000000000000000000000000000000000000000000000000000000000000000000 88F1
FE 05 0C 01 00 00 00000000000001 DE60
FE 22 0D 01 00 03 000200000000000000000000000000000000000000000000000000000000000000000000 49AF
FE 05 0E 01 00 00 00000000000001 6562
FE 22 0F 01 00 03 000200000000000000000000000000000000000000000000000000000000000000000000 F69A
ID ID ID MCRF4XX
FE 03 00 01 00 00 0001020001 8F68
FE 03 01 01 00 00 0001020001 A844
FE 03 02 01 00 00 0001020001 C130
FE 05 03 01 00 00 00000000000001
ID ID ID MCRF4XX
FE 05 00 02 00 00 000064007A0001 0180
FE 05 01 02 00 00 000064007A0001 5405
FE 05 02 02 00 00 000064007A0001 BA82
FE 05 03 02 00 00 000064007A0001 EF07
FE 05 04 02 00 00 000064007A0001 7785
FE 05 05 02 00 00 000064007A0001 2200
FE 05 06 02 00 00 000064007A0001 CC87
FE 06 07 02 00 01 000316085F36ED37 293D
FE 05 08 02 00 00 000064007A0001 ED8A
FE 06 09 02 00 01 0003EA07BB360038 0D65
FE 05 0A 02 00 00 000064007A0001 5688
FE 06 0B 02 00 01 0003EE07E0370038 142F
FE 05 0C 02 00 00 000064007A0001 9B8F
FE 06 0D 02 00 01 0003F007DE370038 7BB4
FE 05 0E 02 00 00 000064007A0001 208D
FE 06 0F 02 00 01 0003F107DD370038 383D
FE 05 10 02 00 00 000064007A0001 D995
FE 06 11 02 00 01 0003F107DD370038 6E57
FE 05 12 02 00 00 000064007A0001 6297
FE 06 13 02 00 01 0003F307DD370038 8F6B
FE 05 14 02 00 00 000064007A0001 AF90
FE 06 15 02 00 01 0003F307DD370038 6176
FE 05 16 02 00 00 000064007A0001 1492
FE 06 17 02 00 01 0003F307DD370038 3B7D
FE 03 02 03 00 00 0001010001 F68E
FE 03 03 03 00 00 0001060001 F0F5
FE 14 04 03 00 05 0014050051325359535F53575F564552000000000000 7F9B
FE 1F 00 03 00 01 004C00000041000000000000000000000000000000000000000000000000040100 324B
FE 05 18 02 00 00 000064007A0001 359F
FE 06 19 02 00 01 0003F307DD370038 BD4D
FE 03 06 03 00 00 0001010001 6A3E
FE 03 07 03 00 00 0001060001 6C45
FE 14 08 03 00 05 0014050051325359535F53575F564552000000000000 2C58
FE 1F 01 03 00 01 004C00000041000000000000000000000000000000000000000000000000040100 FAE1
FE 05 1A 02 00 00 000064007A0001 8E9D
FE 06 1B 02 00 01 0003F307DD370038 E746
FE 03 0A 03 00 00 0001010001 DFE7
FE 03 0B 03 00 00 0001060001 D99C
FE 14 0C 03 00 05 0014050051325359535F53575F564552000000000000 1D19
FE 1F 02 03 00 01 004C00000041000000000000000000000000000000000000000000000000040100 B316
FE 05 1C 02 00 00 000064007A0001 439A
FE 06 1D 02 00 01 0003F207DD370038 DCC4
FE 03 0E 03 00 00 0001010001 4357
FE 03 0F 03 00 00 0001060001 452C
FE 14 10 03 00 05 0014050051325359535F53575F564552000000000000 9BD6
FE 1F 03 03 00 01 004C00000041000000000000000000000000000000000000000000000000040100 7BBC
FE 05 1E 02 00 00 000064007A0001 F898
FE 06 1F 02 00 01 0003F307DD370038 5350
FE 03 12 03 00 00 0001010001 A45C
FE 03 13 03 00 00 0001060001 A227
FE 14 14 03 00 05 0014050051325359535F53575F564552000000000000 AA97
FE 1F 04 03 00 01 004C00000041000000000000000000000000000000000000000000000000040100 30F0
FE 05 20 02 00 00 000064007A0001 B1AB
FE 06 21 02 00 01 0003F307DD370038 A58F
FE 03 7A 03 00 00 0001010001 43C8
FE 03 7B 03 00 00 0001060001 45B3
FE 14 7C 03 00 05 0014050051325359535F53575F564552000000000000 363F
FE 1F 90 03 00 01 004C00000041000000000000000000000000000000000000000000000000040100 3F6E
FE 05 36 02 00 00 000064007A0001 A4B9
FE 06 37 02 00 01 0003F4071C36FF37 3016
FE 26 7D 04 00 01 0008000000000000000000000000000000000000 9E7 FF8 008 008 008 008 007 B98028882ABFFFFFF00 8643
FE 11 7E 03 00 01 00FFBC0901C80100000000000203040403B361 46C2
FE 26 7F 04 00 01 0008000000000000000000000000000000000000 9F7 FF8 008 008 008 008 007 B98 028 882 ABFFFFFF00 9C18
FE 26 80 04 00 01 0008000000000000000000000000000000000000 A07 FF8 008 008 008 008 007 B98 028 882 ABFFFFFF00 2709
FE 26 81 04 00 01 0008000000000000000000000000000000000000 A17 FF8 008 008 008 008 007 B98 028 882 ABFFFFFF00 7008
FE 26 82 04 00 01 0008000000000000000000000000000000000000 A27 FF8 008 008 008 008 007 B98 028 882 ABFFFFFF00 890B
FE 26 83 04 00 01 0008000000000000000000000000000000000000 A37 FF8 008 008 008 008 007 B98 028 882 ABFFFFFF00 DE0A
FE 03 85 03 00 00 0001010001 F5E8
FE 03 86 03 00 00 0001060001 BDCB
FE 14 87 03 00 05 0014050051325359535F53575F564552000000000000 0F0B
FE 1F 91 03 00 01 004C00000041000000000000000000000000000000000000000000000000040100 F7C4
FE 05 38 02 00 00 000064007A0001 85B4
FE 06 39 02 00 01 0003F5071C36FF37 63B9
FE 26 88 04 00 01 0008000000000000000000000000000000000000 A47FF8008008008008007B98028882ABFFFFFF00 5E6D
FE 11 89 03 00 01 00FFBC0901C80100000000000203040403B361 3F46
FE 26 8A 04 00 01 0008000000000000000000000000000000000000 A57 FF8008008008008007B98028882ABFFFFFF00 4436
FE 26 8B 04 00 01 0008000000000000000000000000000000000000 A67 FF8008008008008007B98028882ABFFFFFF00 CB59
FE 26 8C 04 00 01 0008000000000000000000000000000000000000 A77 FF8008008008008007B98028882ABFFFFFF00 06EC
FE 26 8D 04 00 01 0008000000000000000000000000000000000000 A87 FF8008008008008007B98028882ABFFFFFF00 48ED
FE 26 8E 04 00 01 0008000000000000000000000000000000000000 A97 FF8008008008008007B98028882ABFFFFFF00 6980
FE 03 90 03 00 00 0001010001 1CA6
FE 03 91 03 00 00 0001060001 1ADD
FE 14 92 03 00 05 0014050051325359535F53575F564552000000000000 A314
FE 1F 92 03 00 01 004C00000041000000000000000000000000000000000000000000000000040100 BE33
FE 05 3A 02 00 00 000064007A0001 3EB6
FE 06 3B 02 00 01 0003F4071C36FF37
Reactions: Pöllö
Ah yes, I probably mixed that up with the PWM pin that definitely requires a specifically timed init sequence. Too much time since did something with the drone last time...
More than, the last CGO3+ FW in the fresh cameras from China is not PWM tolerant at all.
That sounds very strange for me, as the PWM has always been used to control the tilt on the gimbal. Where I could find more information regarding this? How fresh CGO3+'s are we talking about? I think I have one of the oldest ones (with poorly adjusted narrow-fov lens) and the later model with wide and sharp lens. Both of them work with PWM. If that's the case, I need to do some adjustments for the Thunderbird firmware...
The CGO3+'s require one specificic pulse on startup if you want to control the gimbal with PWM. If they do not get this, they won't accept PWM commands later on. I had to figure this out based on info here and elsewhere, and to modify the bootloader I'm using in Thunderbird to produce this pulse/sequence in few seconds after powerup before I could launch the actual NuttX RTOS and PX4.
PWM pin was TX or RX, don't remember exactly. Just attach some analyzer as a Saleae and you will close this question in no time. I used a two-channel UART<>USB because for me the init itself is not important at all. My goal was to listen to both lines and to catch the redundancy too. This is almost done, enough for proper beacon with telemetry and ST16 position.
If you want to discuss something more in deeper detail, PM us in the invited thread, please.
Reactions: Pöllö
daps20
