Typhoon h team mode
Just curious, but I am going to use the YUNEEC wizard for the first time on my typhoon h, if I do team mode and the wizard runs out of battery, does the controls just switch to the st16?
You might be able to tell by setting up team mode, removing the props and starting the motors. Then turn off the wizard.
With a full charge on the Wizard you should have power on it for well over an hour. If connection is lost between the controller and the aircraft it should pause in flight and wait trying to reconnect for 30 to 60 seconds then do an auto RTH back to the last known position of the controller piloting the aircraft.
Control will not revert to the controller manipulating the camera.
Yuneecfan49
