Barnitcz, the recording will continute, no probs at all. I use with excellent result an ITELITE DBS antenna. Be careful to aim it direct to you H. Don't try to fly wth your H behind you as you can with the std antenna.Hi
Typhoon H:
Range of control 1600m.
600m video transmission range.
Is video interrupted = interrupted recording?
How to fly at a distance of 1000m and record a video?
Is my dron spoiled? At 320m I lose video transmission, but I have a control signal. When the video signal is missing, recording is interrupted. After the return of the missing part of the film.Barnitcz, the recording will continute, no probs at all. I use with excellent result an ITELITE DBS antenna. Be careful to aim it direct to you H. Don't try to fly wth your H behind you as you can with the std antenna.
Hello, in my case recording was selfstopped after the distance of 300m. - i am concerned if my Thyphoon is broken? As I understand if there is 1600m control range, my dron should record all the time even if the video transmission is stopped?
4:27 - 4:28
Yes, I have checked sd card. Recording is only till the time of interruption at 300m.It does continue to record on the sd card in the camera. The recording inside the ST16 records what is received by the wifi signal, so that will have interruptions. Did you check the camera card recording?
You probably already know, but the camera records only 5 minutes at a time and then will automatically start another file to continue the recording. Did you check the other files? Or is the SD-card full?
Do interferences affect the recording itself? The video is interrupted, but will the recording also be interrupted?Have you changed where you are shooting? There may be interference issues. I just took my H to 800m last weekend and did not even have a glitch in video or control.
I would imagine it shouldnt stop the recording. It performs fine while closer?Do interferences affect the recording itself? The video is interrupted, but will the recording also be interrupted?
I also had this problem at a distance of 10m.I would imagine it shouldnt stop the recording. It performs fine while closer?
Can you see what happens to the LED when it is close and fails on you? Have you reseated the camera?I also had this problem at a distance of 10m.
The sd card in the camcorder is ok. All recorded videos are ok. The problem occurs when the video transmision is interrupted (then interrupts the recording)Which sd card do you have in the camera? Does it say U3 on the card?
