- Joined
- May 9, 2017
- Messages
- 8
- Reaction score
- 0
- Age
- 39
I finally received my Typhoon H 3 antenna kit.
1.) I'm planning to re-modify my radio tx, for best result, how many inches is needed for the spacing of each antenna?
2.) I also have a 3DR solo, will these 2 Half Sphere LHCP work on the Radio tx?
3.) If you view the 2 Half Sphere LHCP closely, the wiring on the left is thicker than the one on the right and is different in color, which one is better to use if I'm just going to use one half sphere and one whip antenna on my radio tx?
4.) The ones on my H are modded RP-SMA, I can fit any type antenna, which one is better? Whip antenna or a 2.4 RHCP Clover antenna to increase range? or should I get LHCP clover instead?
The ones here are 2.4Ghz RHCP clover antenna. I placed the rp-sma on the sides instead of the traditional bottom that are found on the net. Was thinking of getting an LHCP clover but maybe for now I'll just use a whip antenna.
