Typhoon H Gimbal Problem
Yes. It would help to know these things:
1.) Does the camera droop when the drone is powered up but the controller is not?
2.) Have you checked "Hardware Monitor"? Does indicator K2 move smoothly as you move the camera tilt?
3.) Have you checked "Final Output display". Does "CH07" move smoothly as you move the camera tile?
WOW... ok, I feel like a total idiot now. I haven't had this out in a while so while I'm in quarantine I thought I would try and troubleshoot this issue. I just figured it out. I was trying to use the pan knob while in tilt mode when the tilt control is on the side of the controller.
Fixed !!
Just reading this now, was going to mention that then I read that you got it
Reactions: McCFly
Easy mistake, repairs are always good when it's an oversight. Happy flying.
There are two buttons undeath the camera which can reset it, but it might not need that.
I see two little 'slits' on the bottom of the camera (CG03+) near the SD-card slot.. BUT no buttons .. Are these slits there to receive a paper-clip or ?
This image is a little clearer and shows the buttons just inside the slots you mentioned. A toothpick or paperclip can be used to activate the reset buttons.
marcojanson67
