The wizard can be used to control the H in single mode. In team mode it is still used to fly the H and the ST16 is used to run the camera. I think there are a number of Youtube tutorials on using the wizard.
Could even read the docs that came with the equipment.
Are you in the USA?
Hmmm......if it loses control signal with the wizard it should enter RTH mode. Yours did not?The wizard does not use the wifi. And if it would loose connection it should loiter and land. At least that's what mine did when I shut it off
Okay great. Had me worried there.My bad I worded it badly the first time around. It came home, flew there for a minute then actually landed.
RTH is the failsafe mode for the H and the Q500. It's been tested thousands of times. If there is a GPS failure with the H it may flyaway regardless of what controller you are using. However, it is my opinion that Yuneec products have much fewer problems than other brands. Such things are actually rare but if it happens you probably couldn't stop it anyway, so just fly and enjoy the experience. And learn everything you can about your equipment.I don't know and I'm afraid to test. Suppose I shut down and fly away??? Then there's no control anymore. [emoji21]
You could certainly do it that way if you choose. There should be no need to calibrate the compass on every flight. The calibration is stored in memory and once the calibration is done correctly it won't change unless you move several hundred miles. In fact, frequent calibrations increase the likelihood of a bad calibration.Piggybacking on this topic.. I am planning to experiment with my wizard for the first time today.
I have read the manual and watched several youtubes; is there a way using the wand to put the typhoon in to compass calibration mode? I like to calibrate the compass on the typhoon every time I fly. From what I can tell the "down button/power button" combo on the wizard activates the compass calibration of the wizard itself.
If not is there any problem with using the ST16 to compass calibrate the typhoon and then shut off the ST16 and bind with the wizard?
Most of my flights occur within 10 or 15 miles of my base of operations so I don't calibrate the compass unless the system tells me to or if the H hasn't flown for a couple of weeks (I have another aircraft so the H480 does sometimes remain grounded for periods of time), or after a firmware update of course. The exception is when I occasionally get jobs further afield and my 'rule' for that is if I've traveled further than 40 or 50 miles away...but that is MY rule, others would have different limits.Good to know. I'll probably dial back on my calibrations but in this case my most recent flight was on the other side of the state so I'll definitely calibrate today.
Thanks.
You can download the Wizard manual Yuneec.com. The upper left status light indicates the mode: Smart, Angle, Home, Watch me, Point to Fly.how do you know what mode the wizard is in? The button on the side doesn't really seem to lock into the specific setting.
