Using Typhoon H charger for steadycam
Hello all,
I was wondering if anyone uses the charger for the typhoon H for the handheld steadycam?
On the charger
19.0V - 4.74A
on the steadycam battery
1400mAh 3S/11.1V 3C (15.54Wh)
Thanks!
Graham
The simple answer is no. The H uses a 4 cell battery which cannot be used to charge the three cell battery on the steadicam.
Hmm, my SC came with a charger. Sure you did not receive one?
Called mine "Action Cam".
I got the Typhoon H and a steadycam on sale over the holidays.
Must have came with its own charger.
Does yours look like this? it fits
12V - 1.5A
Not sure I understand completely.
However, my charger for the Action Cam is just a wall wart, but the specs match well enough. 100-220 VAC in, and 12.6 DC out at 1 amp. The one in your pic should work fine. Did you not know what it was for?
Thanks for the help.
This charger was still in its packaging there are a bunch around here.
It seemed to charge it will keep an eye on it.
Plad
