- Joined
- Oct 12, 2016
- Messages
- 54
- Reaction score
- 16
- Age
- 65
The thing I would most like to see is a comprehensive preflight checklist that can be downloaded and printed for the gear bag.
Thanks aredub this will come in handy for sure.@Phil Vanderloo @Air One ......Here you go.
I originally created this in excel, with our company logo in the top left corner, so excuse the generic heading.
Also, I had is set up so when I selected the PIC and Oberver, it would automatically fill in their respective Certification number. The same goes for the aircraft. Everything we own has an asset number, so as soon as I type that in, it would automatically fill in the Make, Model, and registration number. I can upload the Excel as well, and help anyone get it setup the way they want it.
Phil
POI within the Task Modes is just flying a circle around a previously set center: elevator for radius, aileron for direction, throttle for altitude, yaw for orientation, gimbal control knobs for cam pan and tilt.I don't see it in the manual - is there any way to set a Point Of Interest and then manually fly the H around with the gimbal staying pointed at the POI, or is the only option to have it orbit around the POI?
No it isn't. But I saw some promising ST16 screenshots for the Typhoon H520. This includes the introduction of live maps on the display for Task Modes (e.g. CCC) IIRC. Maybe some more features will come with it and probably the "normal" H (480) can profit from it... (that is just guessing, I know)I don't think Litchi is available for my H, is it?
Switches in proper position, yes. I would add preflight items that are absolutely essential, to include checking stick controls to be sure they return to zero. As a pilot, I know missing a checklist item could be fatal. "They call me...'Captain Obvious'"I'd suggest a very short 'Quick Start' section that doesn't overwhelm the user, but just gives the bare minimum information to get them to think about keeping the Typhoon under control. No more than four or five points, and avoiding any 'technical' speak. There could be sections later on on setting up/troubleshooting (in particular, checking the ST-16 controls) and calibration, but the most common causes of problems need to be there up front rather than buried in a chapter twenty pages into the manual.
Something like this?
Getting Started:
The Typhoon is easy to fly. However, like all UAVs, it's also easy to fly into a tree and break. To avoid a costly mistake, there are a few steps you need to take first.
1. Make sure the batteries are charged up, and the Typhoon battery is fully inserted (it clicks into place)
2. Remember: If you are in Smart Mode, the Typhoon will not come closer than 26'/8m. It will back away if you approach it and might not want to come down to land. If you take off within this distance, it will only move away from you. This is the most common cause of early crashes.
3. If it isn't flying the way you expect - stop immediately.
4. Before you take off, check over the ST-16 to make sure you have all the controls in the right position for your flight. Taking off in the wrong mode can cause a lot of trouble.
I haven't looked at it in several months. I think it got left in the dust. Hope someone has the time to put the finishing touches on it.So after reading 5 pages this thread just stops? Is this manual complete and ready to use?
There seems to be a lot of white space. So if I wanted to print it for study, it would take more pages. If it is complete I would reduce the unused space and make a pdf file. Sorry if I missed something. Late to the party......
