What is the AMP's of the ESC ?
Hi, can someone tell me the amps of the ESC on this 920?
Thanks for your time and help.
I don't think there are any official information. Since the original battery has 4000mAh and a maximum discharge rate of 8C (in reality even lower) the power supply is a maximum of 96A. Divided by 6 equals 16A per motor. I don't think the ESCs are rated for a continuous current of more than 20A. The peak current might be a little higher.
This fits to what I would expect a multirotor of that size to use. A high quality ESC with 20A and good cooling should be enough for its needs. Maybe 30A if you want to be safe.
Thanks for the reply, I’m going to build a 920 with a DJI N3 flight controller and was try to figure out what amp esc I should look for. So Thanks for your time and help.
Patynowy
