First let me say to YUNEEC... You have a "flyaway" problem with the Typhoon H.
My Typhoon H did what many others on this forum have been saying... It literally flew away out of control!!!! I'm running the latest Firmware.
I have the flight data and when you replay it, you can clearly see that the Typhoon H does not have a clue where it is. Each time I switched it into RTH it was like it went through a time portal and appeared elsewhere.
Here is what happened, and here is what I did to save it:
1. Travelled to 4 separate areas about 10 km apart from each other. Flew a battery at each location and everything was as it should be.
2. Arrived at fourth location. 4th battery inserted. Camera connected, plenty of satellites with screen showing READY. Took off in ANGLE mode (I never fly in SMART MODE). As the Typhoon H raised up between trees it was drifting to the left so I gave it full power to rise above the trees before it crashed into one. At about 30 meters it immediately QUICKLY started drifting to the left. All yaw & directional stick input had ZERO effect.
3. I could tell that the Left stick to ASSEND or DESEND was working, but with slow results. The Right stick input DID NOT produce desired results. It was as if the right joystick was not working.
4. I switched it into Return To Home (RTH) mode and it shot off at a 90 degree angle AWAY from me. It did not perform any of the RTH movements (i.e., rise and turn around, etc). I noticed that by hitting RTH it would cause the FLY AWAY to go in a different direction, so I kept flicking in and out of Angle mode and RTH mode.
5. Since there were people, cars, trees, swamp, water all around I kept the Typhoon H above the trees so that it would not crash. If you panic and bring it lower to the ground while it's out of control, it will crash.
6. Finally after a few minutes of flicking in and out of the modes it began to fly less erratic at HIGH SPEED until finally it just flew erractic at a SLOWER SPEED and began to drift. I finally was able to get it to begin a true RTH process where it rose up and came to my location (slower than normal). I put it back in Angle mode and landed it safely. As it was coming down it was flying perfectly as if nothing was ever wrong.
If any Typhoon H pilot encounters their Typhoon H doing the FLY AWAY thing, then I suggest to do the following:
1. Don't Panic
2. Raise it above all objects surrounding you (the left joystick hopefully will work to raise it)
3. Keep trying to regain control by switching between RTH and ANGLE & SMART mode (but don't leave it in SMART mode)
4. Try the RIGHT joystick and expect it to not produce the desired results, but keep trying as you don't want it to keep flying in the same direction or you may never see it again.
5. It may take two minutes for the Typhoon H and ST16 to begin to work as per normal.
6. Once you regain control and all is well, crack open a cool one.... You deserve it!
Yes I'll be in touch with Yuneec this week to advise them that they have a problem.
I also plan to post a video showing how screwed up the Typhoon H is during a flyaway.
