So was this a battery for a Typhoon H or for a H520e? The procedure is the same but the adapter would be a different one than pictured above.Thank you very much, I have no idea what it may have downloaded, it was stored in the suitcase in its section. the cable was woven, since I bought it for the yuneec A10 charger that I had adapted for the Typhoon H. I will try to follow the instructions thank you very much
Good morning, I have tried charging in NiMh 1V mode, but the second it gives me a connection error because it does not recognize the battery of this type so it is not possible in this way in the charger either.You would need an adapter cable like this View attachment 26889
And a third party charger that can charge LiHV packs and NiMH packs. You would have to charge on the NiMH setting at 1A or less until that cell comes up to 3.4V. Then change to LiHV balance charging at 1A or less. Constantly monitor the pack to ensure it does not start heating excessively. Once you have it charged be very cautious in its use until you determine if it is trustworthy.
Any idea what caused one cell to discharge and not the others? Possibly connected to a charger that was not powered up?
