Best way to take screenshots from ST16
St16 can only do 720 resolutions
Best method is to use your computer/laptop using the micro card.
Press and hold the middle tablet button for three seconds and the St will record everything on screen into a Photo stored in the gallery, as AH explains - it will only be a 720 P size image however
Reactions: DCH
In Cameras I have got SanDisk MicroSD Gold ones with 64 Gb of capacity, in ST 16 I have a normal micro SD card from SanDisk also but Ultra model with 16 Gb of capacity.
On the other hand, if you are talking about recording the screen as a video, to capture all of the screen info, you will need to get an HD recorder and use the HDMI output from the ST to record video capture of the screen.
Reactions: ParagonDrone
Hey @Ty Pilot , does that recorder “pass through” the HDMI signal?
As in: ST16 HDMI —> Recorder —> FPV Goggles or TV Monitor.
So, while recording, it will also pass the signal to another device?
Hello,
I did a review of a firmware update, a while back, and recorded it. Audio comes from on-board mic.
You can record the screen with Mobizen:
Mobizen Screen Recorder - Record, Capture, Edit – Apps on Google Play
However you will need to root and install the Google Play store to achieve this, so some Googling may be involved.
DianApps
