bras rétractable ne remonte pas sur typhoon h
bonjour quelqu'un a déjà eu un problème sur le train d'atterrissage sur le yuneec typhoon h car il ne remonte pas
Yes, this may happen if the drone wasn't in use for a longer time.
Remove the camera, power on ST16 and the drone and turn it upside down. Then switch the landing gear switch some times up and down. Maybe you must help the servos a little bit at the first try. Good luck.
wholewheatflour
