breeze fault codes
No, when mine starts it beeps and flashes red a lot more than normal startup and then goes to blue flashing light for wifi connection.
Refer to this thread How To: Troubleshoot the Breeze and Request Help in the Forum
Report results from following the checklist.
Unit had crash.Broke one prop blade(replaced): on startup unit beeps flashes red and emits beeps longer than normal. i thought beeps may be initialization code error code. Have reset unit..: will not calibrate. one time came up with gyro error. Just found one aerial in leg broken wire::camera works and adjusts WiFi works . No GPS, IRS Compass or IMU. Any help would be appreciated thanks Kev
Use the guide in this thread to access the electronics in the Breeze Breeze Disassembly Guide
Sounds like the M7 board has issues. Check the cable that connects the M7 to the A9 board has continuity and is fully seated. No IRS could mean a bad solder joint where it attaches to the M7. Check the connections for GPS and Compass on the M7 also.
Reactions: WTFDproject
Thanks for info.will trythis. Having Cataracts done so will be a short delay in gettig back. Should have waited till I had them done betore I flew drone
thanks forum guys for info
i finally have the breeze back in the air
I think the M7 board was problem although i did change compass and GPS boards
Your support and info is much appreciated
kev
dee909
