Breeze GPS Failure
This is a link to the Breeze Disassembly Guide I made a few years back Breeze Disassembly Guide
With it being a .pdf file it should be easy to translate to a different language if necessary.
Accessing the GPS board is simple. Just remove the small cover on the top of the Breeze. Changing it out can be a bit challenging due to routing the cable through the upper shell.
rampagenlv72
