Camera C23 flexible connector
Maybe someone has a broken Yuneec C23 camera with a good flexible connector shown in the photo.
After the drone struck the ground, the rotation of the chamber was broken and the chamber rotated a couple of times around the vertical axis, then this flexible connection was broken
  • Sad
Note: The C23 and E90 use the same parts, so all parts are listed as "E90".
The part number is: YUNE90119SVC (E90 Main Ribbon).
You may also hear the term "C23 Spiral Ribbon" used to describe it informally.
A couple of months ago, Vertigo Drones (in the US) implied they had the part in stock, but would not sell it. They would only allow you to send the camera to them for installation. I do not know its availability elsewhere. If you find it, please post where you find it.
Yeah, that ribbon is a problem.
through forums I found in Germany, used, but in good condition, and inexpensive. The hardest part was repairing the carcass, the camera twisted from the impact, it broke the corner, and there was no restriction on rotation.
Ludwig
