Camra and drone parts needed electrical board for a CGO3 4K
The board doesn't look obviously damaged other than the three black wires are pulled off. You can either remove the black wires completely and use the pigtail, or you can solder the wires back on.
The board can't be replaced by end users. It has to be calibrated to match the encoders, end stops, motor/bearing drag resistance, any balance variations and the IMU.
need one of these.
Your timing is perfect. In the past, we would be telling you that the boards cannot be replaced without sending to the factory for recalibration. However, in the last couple of days, one of our members has developed a working version of the calibration software. See link in thread The elusive calibration software .
The boards can sometimes be found on eBay. (Most "parts cameras" on eBay are NOT a good idea, because they are there for the same reason. They won't say "bad gimbal board". They will say "untested".)
Either of our Forum Sponsors may occasionally have some in stock.
"YUNCGO3105" should produce results on web pages or even on the general internet.
Apologies for jumping so fast with the first response. I should have asked more questions to better understand if your issue is the gimbal board or perhaps a different issue.
  • What are the symptoms you are seeing?
  • Did anything happen between the last time the CGo3 worked properly and the first time it did not? (crash/hard landings, LONG STORAGE, firmware updates, repairs, modification, etc.)
  • If the camera is emitting any beep codes, please describe or record the sequence.
Reactions: Pier2162
EarnestRin
