CGO2+ LENSES
Ontario, Canada
I know filters are not available for the CGO2+ cameras... If the CGO3 camera covers fit the CGO2+ then that would solve the problem...Does anyone know if this is the case? Thanks
Hi,
when I compare this image
with my cgo3 I would say try to use this for mod your cgo2(+)
Yuneec CGO3 Replacement Covers
I think it is possible, you can use/change the front cover and then use the filters.
Another question along the camera topic, where can you get the plastic inserts that you slide into the bushings on the gimbals to also help it from coming apart, looks as if there are two in the above photo, I know that the DJI ones do not fit , already tried that.
ValuAnalytics
