Cgo3+
Cgo3+ is having issues with a used typhoon h.
When you watch any video and only in playback, I'm getting what I think is static like recordings or washed out completely with different colors.
The video has good parts and bad, but unwatchable.
Is this the wired connection to the camera, maybe the gimbal connection with the contacts or maybe even a crappy sd card. Does anyone know how to clean up the video or aware of a fix. Thanks
Are you taking the video directly from the sd card in the camera or from the controller?
If it's from the sd card in the camera then your sd card adapter is faulty. A bad adapter will not transfer clean video to your computer. Had it happen several times.
Reactions: AH-1G and 7cyclops
luffy
