hanks SteveIt appears they have them for sale on this site. If you have a damaged camera they will take it on trade.
hanks Steve
I will communicate with them.
Let me ask you about this message, when I try to bind the camera.
ST16 says: PLEASE CONNECT TO RECEIVER
Sorry, I don't know how to write much in the forum
@Lrafael72
CGO3+ connection issues can be caused from defective WiFi modules in the camera, ST16, or both. Antenna issues can also be a factor.
If you have a phone or computer that has 5.8GHz WiFi capability (802.11a/ac) you can use that to test if the camera’s WiFi is working. With the camera powered on look in the WiFi listing on the phone or computer for the SSID CGO3P_xxxxxx (x’s are the last 6 digits of the camera’s MAC address) select it and enter the password 1234567890. If you are able to connect the camera’s WiFi is working.
If you have a home WiFi that supports 5.8GHz WiFi you can test the ST16’s WiFi module. Go to Pad on the ST16, select the Apps menu (icon with double row of three dots), select Settings, select WiFi, select your home Wi-Fi’s SSID, select Connect and enter the password when prompted. Make sure to select a connection that uses the 5.8GHz to test the portion of the ST16’s WiFi module that is used to connect to the camera. The WiFi module also supports 2.4GHz WiFi bands, but that is not used with the CGO3+.
Hi DoomMeister@Lrafael72
At this point I would suggest checking the Hardware monitor in the ST16 System Settings screen to make sure all controls (sticks, buttons, switches, and dials) are functioning correctly. If that is the case then exit to the main screen and double tap the Volts icon to bring up the Final Output Display.Hi DoomMeister
I did the first test on the camera's Wifi.
Apparently the camera communicates with the st16. The photo included shows that the camera is detected by the st16.
The camera works in terms of video ... I see the image in st 16.
BUT THE CAMERA DOES NOT OBEY THE UP, DOWN, ROTATE 360, TILT COMMANDS.
If I try to bind the camera with the st16, it gives me this message
PLEASE SELECT A RECEIVER.
What is this?
The camera emits a beeeeeee cound.
The PC never ask for the SSID label CGO3P_xxxxxx (x’s are the last 6 digits.
The Wifi test between the PC and the st16 apparently passed.
In the photo of the Pad you can see that the PC and st16 are connected
Finally I think that the problem is in the mechanism of the camera.
I think I should wait for your opinion before ordering a replacement camera or sending my camera in for repair.
Thank you very much for your help. I'm not very good in electronics
The bind screen has two sides. You apparently did the right hand side, which is the camera. You also have to do the left hand side, which is the drone. The camera is always in the bind mode. The drone has to be put in binding mode as described by @Steve Carr and @DoomMeister above.Let me ask you about this message, when I try to bind the camera.
