I've had a problem similar to that of another member here... Can someone point out what's gone wrong?
I did a periodic check for updates on Saturday evening and as it suggests, I re-calibrated the compass after re-booting. All went swimmingly until I get through all the rotation steps - all green, it seems happy - to where it says reboot prior to flight. When I clicked reboot drone, I got a spoken error message "command denied during calibration, error 246" 24 times.
I tried manually rebooting but that doesn't work. Also made sure remote is connected to the drone and only about 35 feet away; so there should not be any communication issues. Drove 5 miles out to a field I own which has nothing around it and tried a couple more times just in case the locality (where I've re calibrated before) was causing a problem.
Any ideas? I've 2 jobs this week, and it will be embarrassing if I can't do one of them as it's a new client, the other appreciates that technical issues sometimes occur. Someone has suggested that the ST16 needs re calibrating but I think that's probably rubbish as the Summary screen suggest a Magnetometer error.
