Created a Thread to Introduce Yourself!
I'm curious to know if there is a professional payload released system designed for the Typhoon H3 drone. Also does flashing the firmware correct the maximum altitude threshold of 400 feet.
The max altitude of 400' is correct. That number is set by the FAA as the maximum altitude above ground level for drones. You should not attempt to change or update firmware unless it is recommended by a senior tech on this forum.
What type of payload do you wish to release?
Budro
